- Joined
- 16 Aug 2019
- Messages
- 26
- Reaction score
- 0
- Country
Hi all,
Just had our upstairs box room re-plastered - old vent taken off, so now an ugly hole into a void... it's a 1940s property - cavity wall - (filled with hay/straw?) and there is an air brick in there.
The air brick appears to be blocked from the outside - can't see through it! - perhaps when it was re-rendered by the previous owner? Anyway, there is a draught that you can feel coming from the hole... I guess from the eaves?
My question is, is it OK to block off the hole in the wall (inside), as we can vent the room via the windows and is it OK for there to be a draught in the cavity wall or would that create damp... my guess is that it would be OK as the rest of the outside wall will no doubt be constructed in the same way and they don't have any wall vents (no damp present and survey done).
Previous owners had stuffed the inside vent with something - may have been more hay - so by blocking it off we're essentially back to how it was. (Not keen on the idea of cavity wall debris blowing into the room!)
Thinking of doing a temp fix and monitor for any issues with blocking it.
Any thoughts? My first post, so go easy!
