I need a few answers please, on a proposed blockwork job that I'm going to do.
I'm doing it, so "Don't do it" won't do
Going to build (on concrete) a blockwork trough 2x1x1 metres internal. Then I'm going to have it rendered internally (and top edge) with appropriate cement. Then I'm going to tile it with glass mosaics (appropriate adhesive)
It wil have a drain, but no filtration, chemicals or heating
It's called a Dip Tank. I'll do the 'Dipstick Tank' joke to save you typing time!
Q1. Will a properly bonded single skin 'trough' take the static pressure of 2 cu m water?
Q2. If 'yes' to that Q, will Celcon type blocks cut it and take the render and tiles?
Q3. Should I build the walls with the 'water resistant' mortar cement?
Q4. Any suggested brands for suitable cement and or tile adhesive?
Thanks for reading.
CG
Thanks for reading.
CG
