Hi All,
I am planning on building a shed using blocks - rough dimensions of 3m * 2.5m I plan to make solid foundations at about 300mm deep and build up on these.
I have been trying to ascertain what is the best block to use. I have become confused with the difference between a concrete block and thermalite block>?
I was planning on building the whole lots (first course to top) using thermalite blocks and then cladding the whole lot with featheredge board (more for aesthetics than anything else).
However, I have read in places that thermalite blocks need to be fully waterproofed so I fear if the cladding leaks the block will be destroyed eventually.
So, am I better to use concrete blocks? If so which ones? Does anyone think I could get away with painting the blocks rather than cladding with wood or would this look ugly?
Many thanks
Many thanks
