Blow Torch Recommendations
18 Mar 2005
I've always used the cheapy DIY blow torches that always run out in the middle of the job!
I'm about to do some plumbing, something like 20-30 joints and I know there isn't enough gas left in the current one to do the job.
So my choices are just buy a few spare gas cannisters for the little torch,
Or spend the money on a better torch with a bigger (maybe better value?) bottle.
I don't have masses of use for a blow torch but do use one a few times a year, either on things like this or on car parts (heating things up before hitting etc!)
I often find the little one isn't man enough for the job.
Any recommendations on what I should buy? Without spending a fortune and remembering it will only be used a few times a year?
It sounds like a blowtorch which takes the mapp gas cylinders would be ideal for you as they get a lot hotter.
Thanks for that I can get a TS7000 for £25 so that should do,
what is better to buy? Mapp or propane?
What benefits would I get from either?
