The fuse for our boiler system has blown. Having replaced it blew again immediatly on turning the power on again. I then replaced again, turning only the central heating pump on after about 10 minutes, it blew immediatly.
This makes me think it is the pump that is overloading the fuse, my questions is, why? The pump is less than 1 year old.
I have a suspicion that water may be leaking from somewhere on to the pump. If this is the case, will the pump work again or will the water have permanently broken this? Clearly I need to find the leak and stop this, but I want to replace the pump asap if need be.
