Hi
I have had cavity wall insulation installed today. It's the type where they drill the hole and blow it into the cavity. I have a few concerns........
1 - the contractor didn't seal the air bricks below floor level, but there's no sign of the insulation coming through. I would have expected to see something???
2 - it appears the cavity trays above the windows are quite high probably about 7 bricks above the windows and patio so consequently there are large voids at the front and rear of the house? Can anything be done about these voids, as due to the large windows there is hardly any insulation on these two walls
3 - as I wasn't entirely convinced that the job was 100% I have removed a brick to check what has been installed. It appears to be very fine mineral wool, thinner than what candy floss looks like. Should it look like this or should it be dense?
I told the contractors that I wasn't happy and they called their "surveyor" who is one of the contractors Dad and he's due down tomorrow to check the work and discuss my concerns.
I just wanted a bit more info or advice before they come back tomorrow.
