I have a patch in my wall (half a meter square) where plaster has blown as its sounds hollow.
Is it possible to fix that section only as remaining part of the wall sounds solid?
If possible then how should I fix it as this is old property and wall is a brick structure:
Not sure which option is best one:
- Remove old plaster, PVA it (what ratio?) and use plaster board and skim it over
- Remove old plaster, PVA it (what ratio?) and use easifil
