Blown Plaster
2 Sep 2006
London
We have just stripped the wallpaper from our lounge walls. (Victorian masionette 1895).
The ceiling has some big cracks 1mm in width and 90cm long.
Regarding the walls, underneath the plaster the original horse hair is severly cracked and crumbling in places, and when I push the plaster it moves.
My questions are.....
Is it worth ripping it all down and getting the plasterers in?
In these type of properties are the partition walls the same as todays. I.E wood joists and plaster board?
finally
or shall I just skim over?
many thanks
Mark
although plasterboard was invented in 1888, it wasnt used in the uk until 1917 so its unlikely you have plasterboard if it is still the origonal wall
Thanks Breezer, I have investigated further it is lathe and plaster, will this still have vertical wood joists from floor to ceiling?
What im getting at is if i rip down the lathe and plaster with there be something to attach the new plaster board too?
Cheers
best thing to do with those walls is reboard over the walls don,t touch the old stuff as your only opening a can of worms find all joists and screw the plaster boards on and finaly skim them
finally
many thanks
Mark
PostPosted: Sat Sep 02, 2006 9:22 pm
Bet he's fixed it by now eh? Nearly four years ago. :rolleyes:
