Hi all
Our house has a fair amount of blue piping in it.... The piping says:
Qualplast
BS6572/1985
20mm
PE
Water
12 Bar
Is that standard MDPE piping or something else?
From what I've just learnt, this should be used underground only. And worse still it is apparently prone to bursting, leaking, etc.
Just wanted to check on here whether that is the case or not.
The areas where the piping is visible are:
- In the loft - from the tank to the section of the loft floor where it drops into the bathroom below. It then runs through a partition wall and comes out at the bottom (beneath the bath). Cannot see whether it is blue pipe all the way through the stud wall, but I'm guessing so... The blue pipe then feeds the cold water tap of the bath.
- Under the kitchen sink (just a little coming out from the floor, at which point it is joined to a copper pipe)
- There is a run of it from the top to the bottom of our airing cupboard.
I've no idea whether the same blue pipe is used under the flooring, etc. Nor do I know how it all connects or runs. But I'll post a diagram and/or any further info that might be needed to see where things are at.
What would be great to know though is if we are going to have to consider having all the blue piping replaced?
Huge thanks
Max
Qualplast
BS6572/1985
20mm
PE
Water
12 Bar
Huge thanks
Max
