Ok, I'm stumped by my BM and need some fresh thinking.
When driving, if I hit a bump or even slight pothole on the rear passenger side, the car bounces violently, shuddering almost and loses traction on that side momentarily. There is also a knock noise that comes from it when this happens.
Stationary if you bounce the car there is no noise what-so-ever and the compress and return rate seems normal enough.
I stripped out the shockie and mount at the weekend and found to my surprise that there is nothing wrong with the shock, no misting of the oil or anything sinister. The top mount looked worn so I thought best to replace. Still the problem exists. Bushes look fine, spring is fine and I can't see anything wrong with the shockie (and at £118 a pop I'm loathe to replace if no fault).
Car is a 2006 (55 plate) E46 2.0 Diesel Coupe.
Anyone have any ideas?
Cheers
Cheers
