Some advice please.
Just passed my NICEIC assessment and the assessor told me that when you do a board change and issue the certificates, you are saying the whole installation is up to current BS7671 regs, if the installation is not up to regs don't issue the certificates.
But I have been to have a look at an extension, which would require updating the old consumer unit, aswell as doing the required wiring, but the problem is some of the old wiring is OLD rubber sheath/aluminium so where does that leave me, recommend a rewire, which they don't want pass it off, then would it be to current regs?
Obviously I would upgrade all the earthing etc, but the existing wiring?
Any thoughts would be appreciated
One more thing, if you add a socket/ light etc, then test that circuit are you saying that circuit is up to current regulations? If not why is this the case for a board?
