Hi
I want to board out my total loft space and have found some really good loft boards with laminate finish and 22mm thick. I have the foot wide joists running all the way down the bungalow side to side and then I have 6 more on top of these running full length of bungalow where they are also resting on brick. Ive been advised I can add additional 3x2 to the existing 3x2 joists which there is a lot from one end to the other to add more support and which will act as a bed for the boards. I have a peril either side with support going down into the side joists and also the triangle trusses coming down from the roof center (I know I cant remove these) or I would need to replace them somehow. Does what Ive said sound accurate? also Im assuming if the boarding is intended for loft space and storage I don't need building regs involved...
