I have an old Lath and plaster ceiling that is cracked, blown and generally in a bad way.
Would it be best to bring it down then plasterboard directly onto the joists (and put insulation between the joists) or overboard directly on the old plaster???? obviously i would need to find the joists if i keep the old stuff up. Is that particularly hard???
When putting up the boards do you put them up long way with the joists or across the joists.
Also is 12.5mm boards the best.
Thanks for any help.
