- Joined
- 17 Jan 2008
- Messages
- 89
- Reaction score
- 0
- Country
I am planning on putting up plasterboard in a small section in my kitchen which is 2280 x 2210 and the joists are fairly close together, approx 40cm.
I have ordered 2 sheets of 2400 x 1200 T/E and will screw in the boards to the joists. A plasterer will skim the joint. The 2 boards joined on the 2400 edge will cover the ceiling.
I assume the 2400 joint should run along the middle of a joist? I.e this would be the plasterboard running in the same direction as the joists?
I’ve attached a rough sketch to try and show what I mean.
Also, is there any other tips?
Thanks.
View media item 78629
Thanks.
