Hi
I want to plasterbaord out my integral garage walls (Brick outer/block work internal) and just had a couple of questions regarding insulations and membranes.
I know walls can be dot and dabbed with insulated plasterboard but it seems battening them could be a better way, does the below sound ok/correct.
Batten the walls with https://www.buildbase.co.uk/homegrown-cls-50-x-100mm-x-10m-10386-2825810 400mm apart
Fill with https://www.wickes.co.uk/Kingspan-TP10-Insulation-Board---2400-x-1200-x-25mm/p/180435 Not sure if 50mm would be better
Then board with foil backed plasterboard like https://www.travisperkins.co.uk/Kna...lasterboard-2400mm-x-1200mm-x-12-5mm/p/858201
One other question was do I need to put a breathable membrane or a vapour control layer onto the blockwork before I put the battens on, not sure exactly what the differences are? such as
https://www.roofingsuperstore.co.uk...MI5Jez7p7w4wIViK3tCh3u7wTgEAQYASABEgIDRPD_BwE
or a Vapour control layer? https://www.jjroofingsupplies.co.uk/klober-permo-light-vapour-permeable-roofing-underlay/?infinity=ict2~net~gaw~ar~331981876075~kw~~mt~~cmp~Breathable Membranes | Klober | Underlays (6)~ag~7424 - Klober Permo Light Vapour Permeable Roofing Underlay&gclid=EAIaIQobChMIisu7y6Dw4wIVQ7DtCh2MsQRLEAQYASABEgIiFfD_BwE
Also I plan to put joists on the floor, which membrane would I need to put down on the concrete floor before putting the joists down?
Many thanks for your help.
