I want to board out my loft - the area is 4.2m x 4.8m wide. The ceiling joists are 4x 8.5cm in size and the distance from centre of each joist to the next is 34cm and the internal distance between joists is 30cm.
Currently there is no ceiling - the joists are exposed.
1) Can I use the placement of the loft legs as shown below - where they are on alternative joists rather than on each joist.
2) Is it better to go with the larger board 60cm x 120cm or the smaller boards 32cm x 122cm?
https://www.wickes.co.uk/Wickes-P5-T+G-Chipboard-Flooring---18mm-x-600mm-x-2400mm/p/164516
https://www.wickes.co.uk/Wickes-Chipboard-Loft-Panels---320mm-x-1220mm-Pack-of-3/p/116420
3) As I will be putting down loft insulation after the ceiling is boarded up - will I have enough clearance? The joists are 8.5cm high and the loft legs 17.5cm - giving me 26cm so 1cm shorter than the required 27cm?
