Boarding out garage loft
10 May 2016
I'm looking to board out the loft space in my garage, couple of questions:
  • Can I remove the diagonal ceiling bracing as the boarding, once fixed down, would be doing the same job?
  • If not, can I lift the diagonal bracing, lay & fix the boards, then refit the diagonal bracing?
I'd leave the longitudinal braces in place which are fixed to the gable end with steel straps.
Thanks in advance,
Thanks in advance,
Did you remove the diagonal boards?
