I've had a Bosch dishwasher for nearly 2 years - however its intermitantly not cleaning well.
Sometimes within the same load (ie some plates are clean others are not.
It is loaded properly, there is salt, arms can rotate freely and do rotate during the cycle (opened and closed the door a few times to check on movement) pressure seems fine (based on a jet of water shooting out the door one time when I opened it at just the wrong point.
The only problem I have ever had with it is that occasionally the drainage stops due to small bits of food (usually seeds) getting through the filter and blocking up the drain - however this is obvious from lots of standing water and a stuck cycle and cleaning out the blockage clears this. This does not seem to be the problem at the moment.
Any suggestions?
Any suggestions?
