I had been reading up on what I needed to do to add a couple of sockets and some lights into my garage in order to educate myself on the correct way of doing things.
The previous owners of the house had already installed a supply to the garage. They had this running three outside lights, three inside lights and a pond filter pump. However, when I started to look at the supply I realised that they had used 1.5mm2 cable. When I investigated further this supply was an unfused spur from a socket in the kitchen which was already running from a spur.
Why on earth do people do this? It's not a secret that you can only have one spur from a socket unless it is running via a FCU and how they can think that 1.5mm2 cable will be enough? The costs are negligible, so what is it?
I can't believe that people are so ignorant, especially with electricity. Its one thing to use the wrong screw to fix your shelves up where the worst that will happen is they will fall down. But using the wrong wire, and wiring it wrong, the result could be fatal.
Needless to say I have removed this cable completely and will be calling in an electrician to run a proper supply from the CU. Anybody recommend a good sparky in the Milton Keynes area?
Rant Over!
Rant Over!
