Hi, I had a plumber replace a bathroom a year or so ago and there is a problem with part of the flooring.
This pic shows the bathroom in its current state (I removed the offending piece of tiling:
On the right you can see that the bare concrete floor is now visible. This was previously a raised and tiled section - the base was some pieces of paving slab and wood battens with WPB (sp?) on top with tiles - as in this pic:
Unfortunately there was a slope from left to right on this tiling which caused spray from the shower to collect in the back corner:
I was concerned about this and took off the tiles to find the wooden board etc is all wet and rotten. Hence me removing the whole lot.
How should I progress with this? I'm thinking of starting as before for the base: attaching some battens to the concrete floor (screws+plugs) and creating a wooden frame (what type of wood will be best) and screwing this to the battens on the floor. With the frame properly constructed (slight slope back into the shower tray), I plan to tile onto the frame as previously.
I'm keen to do this right so any ideas on making this solid and impervious to water appreciated.
The tiled floor area will get wet when the shower is used so any other suggestions instead of tiling would also be appreciated.
I really hope the above makes sense & the pictures are there!
cheers
Adam
cheers
Adam
