Hi All,
I've posted a while ago about having my boiler and thermal store replaced. I live in a 4 bed townhouse and the boiler (suprima 60) is in a kitchen cupboard and the boilermate (185L) in the airing cupboard on the top floor. There's 2 ensuites and a family bathroom.
One installer quoted for changing to a system boiler with a 210L unvented cylinder in the airing cupboard. When I asked how he'd get a gas supply there he said the existing flow (might've been return) pipe from boilermate to boiler could be converted to a gas pipe.
When my wife found out she'd be losing all her airing cupboard he said that the whole lot could be moved up into the loft.
I then had another quote, and that was for a 250/260L unvented cylinder in the airing cupboard and an open vent boiler in the kitchen. When I mentioned the possibility of moving the boiler and converting the current water pipe to a gas supply he freaked out and said you should not do that. He also felt a 260L cylinder would make more sense than a 210L, as he felt if we had friend stay and everyone used the shower it could run out of water.
I also suggested about having the cylinder in the loft and he said that was not recommended either. Apparently my loft has 4 inch joists, compared to nearer 7 inch for the floor joists. He said he wouldn't be happy putting a 260L cylinder in the loft.
So my questions are:...
Can/Should a current boiler flow/return pipe be converted to a gas supply pipe?
Would it be safe to install the cylinder in the loft?
What size cylinder would be recommended for my house? There's only me and my wife at the moment. But planning for the future and we occasionally have friends stay. If we go for a 210L in the airing cupboard there's still room to use it as an airing cupboard. If we go for a 250/260L cylinder then it's completely used up. I don't want to be in a situation where we could run out of hot water, but also don't want to oversize unnecessarily.
Any advice on this is much appreciated...
Many Thanks...
Many Thanks...
