I had a leak in the cylinder pipes.
So I had to drain all the water, and undone the hot taps, and drained the cylinder.
After fixing the leak, I opened the stop cock and released the cold water.
After a while the water rushed through the hot and cold taps.
I put my boiler on (Potterton) to heat the water.
After a while the boiler switched off.
I also noticed that there was no water in the radiators.
This may be due to air in the system.
I would be extremely thankful for advice, to sort out my problem.
How would I remove the air and why did the boiler switch off on heating the water?
pindy
pindy
