- Joined
- 24 Nov 2019
- Messages
- 39
- Reaction score
- 2
- Country
Hi all.
I recently had a new boiler (glowworm energy 30c) fitted along with a nest thermostat.
Everything seemed to work fine. I had a small incident early on whereby the CH stopped working. After a bit of investigation it turned out to be the motor had stopped working within the actuator on the zone valve. I got a replacement actuator and all was good.
Now I find that the boiler and pump seem to intermittently carry on running when there is no demand for heat from the thermostat. After an inspection I've concluded that the microswitch might be failing in the new actuator I fitted and it is stuck on. It doesn't happen all the time. It could also be the microswitch on the water actuator. One of the two.
Does this sound like a likely cause? But if the zone valves are closed where is the water being pumped to?
