Boiler broke down last week with no hot water and heating. Think i have worked out the problem but thats as far as i go. BG have quoted £2 a month membership and a fixed fee of £127 to fix it. Seems ok to me.
However the boiler has only an on/off switch with no timer or termostat, so basically when the heating is on its on full whack which is using a lot of energy meaning higher bills and unwanted heat in parts of the house. So whilst im getting the above fixed im thinking of getting the neccessary equipment installed but not sure which is best.
A timer i want to get the heating on before we wake up or babies bath time etc. Though im stuck with the thermostat. Ideally would i need one for the boiler/heating itself and thermostatic valves on the rads or will just having the valves on the rads be sufficient as if set correctly to ideal heat there would be no need for the main heating/boiler one.
Thanks in advance.
Thanks in advance.
