Help my Ideal response combi keeps backfiring ie very loud bang from the flue, also once the Ch fires up it shuts down after 20 mins, even with thermostat on full temp...please help
When was it last serviced? Could be spark gap too small, duff spk gen, poor inlet working pressure at ignition. Ideal have a new improved ignition board now(pcb 41) which sparks then opens gas valve. Instead of sparking and opening gas valve at the same time.
