simple way to try and locate the item causing it ceaser is simply disconnect each item in turn till fuse stops blowing lol.start at gas valve and work backwards .worst that happens u run out of fuses hope this makes it a bit more simple
There is a cost free and immediately visible way of dealing with fuse blowing.
Thats just to connect a 100w or 200w bulb in series with the boiler supply.
Immediately the failing component draws excessive current the lamp lights!
Unfortunately, BOB has fallen into the trap of a fan with a resistance of 44 ohms.
The amswerr is that it has inductance as well as pure resistance and together they present an impedance to the supply and its the value of the impedance that determines the current taken.
Its more involved when its a fan!
The impedance will fall if its stalled ( i,e, rotor stalled ) and will vary according to the resistance presented to the air flow.
Contrary to the expected result the current taken will REDUCE if the air flow is restricted.
Tony
BTW.........how do I underline my posts and make a comment. like.no to pointless signitures?
________________________
Say no to pointless signitures?
Or even "signatures" if you prefer.
FEK bet cider is walking funny now .
Caesar";p="1024123 said:Hello All
Had the CORGI Engineer in again and fixed the problem by replacing the PCB (Not that I know what it is or what it does)! Many thanks to everyone for thier kind input, learned a lot.[/quote
Thank YOU for reporting the outcome. learned as much as you, as have other readers.
