I need some advise on fitting TRV's and a boiler bypass valve to my central heating system.
My heating setup is as follows:-
- Heatline Viso 24 Plus combi boiler
- 4 rads upstairs no TRV's fitted
- 5 rads downstairs no TRV's fitted
- a room thermostat in the room next to the boiler
- no boiler bypass fitted although there is a tap between the heating outlet and return
This years heating bill has been huge so I want to introduce better control to the system. My plan is to add TRV's to all the rads but not to the one on the rad where the room thermostat is.
I have a couple of questions I need advise on:-
- do I need to fit an automatic boiler bypass valve? Currently there is a tap fitted which is mostly closed. If I leave out one TRV will this be sufficient to act as a bypass?
- one of the bedrooms is distant from the other rooms and often the rad struggles to get warm. IM guessing its the lack of TRV's on the other rads which is causing the lackof warmth or could it be another issue?
The boiler controls are crude, can any one recommend an alternative to the 24 hour analog boiler programmer and room thermostat? I believe some kind of digital room thermostat could be used to control both the boiler on/off and room temp, but which type and how to wire it in ?
All info welcome.
All info welcome.
