Have a worcester Bosch 30 cdi.
Circulating pump stays on in the evening and would stay on throughout the night if I didn't turn off boiler.
had someone round from WB, and wiring is ok. Though he didn't think there was a need for a frost stat given that piping was not that long and far from the boiler.
Apparently a frost stat runs the circulating pump only on this model and that would kick in the frost stat in the boiler etc etc.
but there still is an issue as at the end of the day the circulating pump is coming on and staying on. I have to set the machine off to stop it. I was wondering if the daily pump run (to stop it seizing when CH not used) could be staying on ? Does that sound like a possible cause?
I have turned on Central heating and the pump turns off after that, so am at a loss to isolate the cause.
