Hello
I need of advice. I have a Range Powermax 155 combi boiler it was fitted when the house was built in 1997, I've been living here the last 5 years.
I have the British Gas Home Care cover for the boiler and I have had it serviced every year for the last 5 years
I had it serviced on Wednesday and the engineer found that it required new turbulators as the old ones had corroded and fallen to the bottom of the chamber, it also required a new ch pump. So he completed all the checks on the boiler and said someone will be out the next day to remove and replace the turbulators as his forceps were not long enough to reach down and remove them.
He checked the boiler with his probe to record gas readings, he wrote on my homecare checklist
4 ppm
9.0%
0.0001 ratio
53 secs gas rate
said the boiler is fine just need to get the 8 turbulators and pump replaced.
The next day...
British Gas engineer turns up to replace turbulators complains that the powermax boilers are pigs to work with.
He replaces the turbulators and ch pump and takes readings with gas burning.... This guy now says that there is fumes leaking from flue seal at base of boiler and on flue, phones his british gas manager tells him then tells me it's not safe to use and caps it off.
I cant remember the readings he took but i remember him telling me carbon dioxide was 2 ppm
He also told me the seals where the leaks were coming from are no longer available and i need a new boiler
is this true is it unsafe can british gas not get the part needed?
is it worth a second opinion?
Do I need a new boiler??
Or do i need to call british gas and tell them they talking garbage
4 ppm
9.0%
0.0001 ratio
53 secs gas rate
The next day...
