- Joined
- 10 Apr 2016
- Messages
- 92
- Reaction score
- 5
- Country
I have an 20yrs heat only potterton 50e boiler with 196x old house - suspended floor - designer radiators, open vent system and hot water cylinder on first floor with two motorised valves and stat.
I want to replace the boiler with minimal cost and max efficiency so thinking of replacing the old boiler with a new condensing boiler.
Currently, the old boiler is set to 70C supply temp to ensure the cylinder gets to 60C to avoid legionella. Also the designer radiators - Milano Aruba - have low BTU output - so the 70C helps getting enough heat out of it.
In order to save money I only heat up the hot water cyl for 30 min before shower.
Question: Can I get a new boiler and new rads that does both 1) provide 70C to the hot water cyl during for 30mins and 2) Operate central heating at low condensing temp?
My solution would be 1) buy a heat only boiler that can normally operates at 50C to feed the rads and changes output temp 70C upon an dry contact signal trigger by cylinder hot water demand and 2) replace designer rads with triple panel radiator and operate them at low temperature.
Finally I don't know whether triple panel radiators can really enable low temp systems, but only underfloor heating can? UFH will cost a fortune I suppose.
