Hi. Hoping someone could advise on this as I`m stuck.
We have an open vented system with FE tank, Grundfos pump and Honeywell V4044C valve in loft and we have a Baxi Bermuda back boiler in our lounge. We live in a bungalow so only one storey.
I had to drain down the system today to remove a radiator for DIY purposes. Have re-filled the system, and bled all of our radiatiors as well as any air vents in loft.
Problem I have is that the boiler doesn`t seem to stay on for very long ( few mins) then cuts out and doesn`t relight after a while. I have set the programmer to water and heating (the only other option is water only) and have set the room thermostat to highest possible but no joy.
I have drained a little more water from the main drain off point and also drained some from the drain off point by the boiler. But still have problem.
Could anyone help please ?
Thank you.
Thank you.
