Hi, my Potterton Gold FSB 30 HE boiler has recently started behaving oddly, which is something else for me to worry about.
It will seem to be running fine, modulated down to a whisper, then will suddenly ramp up to what I presume is full power and will then switch itself off almost immediately. The radiators at this stage are just warm. Then after a few minutes it will start again and be ok for maybe 5 minutes, then it will happen again. The boiler doesn't display a fault, no reset is needed, but operating like this it takes ages for the radiators to heat up fully.
The pump seems to be running ok at all times. The radiators do heat up eventually, all of them, and there is no air to bleed.
I wondered whether it could be the thermistor, but the pattern of behaviour is hard to reconcile.
Can anyone suggest what might be the problem?
Many thanks
Many thanks
