I have a vented CH system and conventional boiler (standard set up)
The boiler was recently given its annual service. The bloke said to have the boiler thermostat up to the max position, the temp sensor up to about 22 degrees, and then balance each room temperature as required on the radiator TRV. (I've been on a couple of energy saving websites and they seem to concur with all this.)
Now, the boiler cycles on and off. On for about 1 minute and off for about 3 mins, all the time.
The circ pump is set to position 2 and all the rads have been bled. There doesn't appear to be any over-pump into the F&E tank or cavitation in the pump.
Is this cycling normal? (i haven't a clue having never had a properly working CH system!)
Cheers.
Cheers.
