Hi
I have a precious boiler it seems, a Baxi Solo 3 PF 30.
When calling for heat or hot water it will run fine for 15 minutes, and then it starts to cycle on and off at one minute intervals until the control stops calling.
If I unclip the thermostat from the pipe it will run fine without cycling so the thermostat is sending the right messages to the PCB and doing it’s job. The pipe is hot to touch. I thought blockage but radiators heat fast and fine with no cold spots. All radiators are less than a year old as is the hot water cylinder.
And the pump too for that matter. Have tried pump at faster speeds, and it does over run.
What else is there to check?
Thanks, Kris
Thanks, Kris
