I have a Worcester Greenstar 24Ri boiler that was fitted a year ago. The installer told me that it has a test phase (which appears to take about 2 minutes and 15 seconds) every time the heating switches on, and a pump over-run (which appears to be for 3 minutes) every time the heating switches off.
The system also has a Honeywell CM51 programmable room thermostat. When the room temperature becomes close to the programmed temperature of the CM51, the heating switches on/off/on … at intervals of about one to two minutes. When the CM51 switches the heating on, the boiler does not usually complete its test phase before the CM51switches it off. The pump over-run means that the pump runs continuously while the boiler goes through part of its test phase repeatedly without getting as far as doing any heating for long periods, or sometimes it will heat for 5 to 10 seconds before the CM51 switches it off, and this has no real heating effect.
What can I do about this? Do I need a new room thermostat and, if so, are there thermostats designed for boilers with a test phase like the Worcester Greenstar? Responses from both Worcester and Honeywell Technical Support have been unhelpful.
