Boiler DHW running Cold
gti
14 Dec 2008
Staffordshire
I don’t know if anyone can help me but I could do with some advice with my boiler please? Basically if I try and fill the bath or have the sink tap on full after a short while 30 seconds it goes cold, but if you run it say a third it remains hot. The boiler is a gloworm 30cxi (I know some people don’t like them) which is about 2 and a half years old.
I read on a forum what while the hot tap is running I should look at the flow and return temp to try and work out if there is a ‘blockage in the heat exchanger’. Well when the tap is fully open the gas bar graph shoots upto max and then backs off a little and then goes all the way down to nothing (at which point the water runs cold). At the same time the temp difference between the flow and return seems to be around 20C to 25C.
My parents have the same boiler and they can run a sink tap at full and it will remain hot, and the temp difference between the flow and return is around 10c
Does it sound like my heat exchanger is shot, or has anyone had any experience with these boilers doing this?
Thanks in advance
Trev
