So we took a radiator off the wall on the weekend in order to paint the wall. Turned off TRV and lockshield valve, drained the water from the radiator etc. Capped off the TRV but it appears that it still kept leaking through the cap (I guess the valve doesn't close properly, never seen that before). We've done this before with other radiators and never had a problem.
Sorted the wall, put the radiator back, reconnected and filled (bleeding the valve when needed). Pressurised the system and all seemed ok, no apparent leaks. Except now the boiler (Baxi Platinum+ 40) doesn't hold pressure. If we fill it to 1, it'll drain fully in around 4 hours. Can't find evidence of leaks anywhere. The potentially leaky TRV mentioned earlier is fine. No indication of anything coming out the PRV. Seems very coincidental that it happened when removing/replacing the radiator.
Any ideas?
Thanks!
Any ideas?
Thanks!
