boiler drain
3 Feb 2007
Middlesex
what is the best way to drain a prisma combi boiler so i can repressure the air also the boiler still sounds active when there is no heating or hot water being called for
not really sure what you mean by pump over run im guessing this means the pump stays active for a certain time after the system has been used. seems to be making a noise long after the system has stopped thanks ps any help on draining boiler
