Good evening all,
I have a glow worm 24hxi condesing boiler, which operates with 2x2port honeywell spring return motorised valves, no problem.
If we want hot water, I turn the boiler thermostat up to about 70degrees and with the cyl stat set about 60degrees I get a cylinder full of hot water in about 40 mins from cold, but most of the time I have just the heating on with the boiler stat set near minimum at 50 degrees giving warm radiators which are fine.
In other words I have either hw or heating on, but not at the same time, as each require different boiler operating temps, is this the correct way of operating the system? or am I doing something wrong?
and when is a condensing boiler operating most efficiently?
Kind regards.
Kind regards.
