glow.worm 30sxi high efficency condensing boiler does not fire up when the hot water control is switched on (either on auto or manual) Boiler fires up ok when central heating is switched on. 3 honeywell motorised valves control upstairs and downstairs heating plus the hot water system. Could the fault be in the hot water cylinder thermostat or the hot water control switch? How could I check these? Or could the fault lie elsewhere?
