We have a large old house, with 2 worcester greenstar ri boilers running in parallel.
When the heating / water timer came on tonight both boilers started gurgling and making low frequency 'revving' noises. The indicator light comes on, then after a few seconds turns off. Noise continues and after a bit the light on again - then off. repeatedly. Turned the heating off and just put the override for hot water only, but had the same problem.
I funted on google and found some suggestions that the condensation pipe may be frozen. I've been outside and checked and this isn't the case.
I've powered down and reset, but to no avail. They're about 5 years old so out of warranty - any suggestions welcome before I call the plumber / engineer?
Many thanks,
A/
Many thanks,
A/
