Was wondering if anyone had an idea as to what might be the cause to the problem I'm having with my boiler?
Turned the heating on this morning and I noticed that the radiator in the room I was in started making a racket. Checked the boiler and the pressure had dropped to 0. So I depressurised it and check all the rads and valves for leaks and didn't find any.
Ran the heating for a couple of hours and was all fine.
I later checked and the pressure had started to fall again to just under 1. I rechecked the rad and valves again and all seem to be fine so I depressurised once again.
This time when I've turned the heating on I noticed that the pressure steadily built up to 3.5, at this point I turned the heating off.
I've left it for several hours and the pressure has slowly dropped to just below 1 again. Turning the heating on once again and the pressure has hit 3 within 5 minutes.
This morning I assumed that there was a leak somewhere in the system, but with the pressure going up when the heating is one I'm thinking its possibly a boiler fault. Does anyone have any ideas on this??
