I have an apollo 40b boiler - fully pumped system with 3 port (mid position) valve, I've turned the CH termstat down to off, diconnected the timer and still found that the boiler and pump fire up.
The pump appears to run continually.
The boiler itself has a High and Low setting both do the same, I did try setting it to low, then waiting for it to click off then turned it to high to see if the boiler would fire up immediately...it didn't.
