My Ideal icos boiler develops to a weird problem. It works fine with heating, but if hot water is required, the boiler has 'c' stayed on and burner led begins flashing, then gone, it starts work. It seems everything normal. After 2/3 minutes, boiler firing stops suddenly and led flashing comes back, this process always repeats. I checked the zone valve of the Drayton actuator (ZA5), it opens (at B) once ignition starts, the orange wire has power (means microswitch opened), the pump works, it is a new pump. During the repeated processes, the zone valve, the orange wire power and the pump are always on, I guess HW is heated by CH when HW zone valve is in open state. If I turn down temp of HW thermostat, I can hear a click, then the zone valve, the orange wire power and the pump are switched off automatically. To me, it seems the zone valve is okay, but somebody says the microswitch could be faulty. I am not sure if the microswitch or the HW thermostat is fault, any idea?
Thanks!
Thanks!
