Hi all, hope someone can help...
Our boiler (an Alpha 240e combi) will fire up for a couple of seconds, then go out, then repeat this about 8 times before staying fired up as normal, until turning off as normal.
When the hot water tap is turned on it works just fine, the flame stays lit until the tap is turned off.
Any ideas what might be causing this? When the boiler is first turned on it works as it should, but once the room is warm enough and then thermostat calls for heat again this happens. The thermostat is constantly calling for heat, I'm pretty sure its the boiler at fault and not the thermostat.
Thanks in advance
Thanks in advance
