Boiler (Gas powered Rayburn) cuts in and out VERY regularly
23 Dec 2012
Suffolk
Dear all,
My Rayburn (with a 36Kw Net Honeywell burner) seems to cut in and out very often, even when heating up. It heats up a pressurised cylinder up stairs and a lot of radiators (14 - but half of them are valved out). I've taken some basic measurements and have deduced that the control valve to the hot ware circuit doesn't really stay open for very long as the cylinder is well lagged - so the problem is down to the central heating circuit.
The pressurised cylinder is very new, but the rest of the system is as we bought the house a year or so ago, and as recently been dosed, but there is a known leak (under the floor somewhere I think). The burner cuts in for a minute then out and will do this all evening - I don't think it is correct.
I can think of a number of reasons but can't really get to the bottom of it
a) the heat exchanger in the boiler is crapped up (but it has recently been serviced by the Rayburn man - no adverse comments about it, and also dosed by the plumber that did work for our extension
b) the pump speed (three speed adjustable) is not set at the correct speed, but
c) the boiler is too overpowered for the number of radiators (given how many are valved out as they're in redundant rooms - i.e the garage!)
d) the system is so crapped up that it doesn't hold much water and can heat it up so quickly. We do live in a hard water area, and due to the leak it must be topped up regularly - but does the circuit get hot enough to give deposits?? This I don't know about. We do have a water softener, I can test if it is NOW plumed (via the filling loop) into the softener - but I don't know historically if it has been, or even if it should be?
e) there's a problem with the hysteresis of the thermostat and it cuts out way too cold, or cuts in way too hot
f) Arrrgh
Is there anyone out there who has had a similar problem?
Nozzle
I doubt any one particular, specific piece of advice will help you... except, may be, call out someone who can troubleshoot the whole system and then advise you accordingly.
I could do that, but it's somewhat lacking in, you know D.I.Y?
I acknowledge plenty of plumbing jobs should not be taken on by the D.I.Yer - anything gas related for a start. For this job, I believe with a pointer here or there I can figure out the problem and direct the plumber rather than having to spend £50 an hour while he figures out stuff and takes a shotgun approach to replacing parts.
I did consider that the automatic bypass valve might be incorrectly adjusted, but the recirc route is quite short and couldn't (??) loose enough heat to cut the boiler in again if it is feeding itself with water that has not gone through the radiator circuit.
Nozzle
I'd be surprised if you get any help at all after your assumption that all of us use a shotgun approach in replacing parts.
