Boiler gurgling noise and F2 error when using sink
29 Feb 2024
I have. problem with my boiler gurgling I had bot gas engine to have a look and he said that wipes might be blocked as boiler side is ok. I then call plumber and all the waste pipe are good as he checked with camera. He asked if I changed something and I only replaced leaking tap and new tap seems to have higher flow than old one. Im really not sure what to do as I had lots of suggestions like to install admittance valve to help balance negative pressure when using sink, refit condensation pipe from boiler away from main waste pipe as this might cause air being sucked from boiler as its closest outlet or redirect condensation pipe outside.
I just can't believe that the new tap might caused an issue with boiler keeps switching off when using tap. Any help and advised will be recommended as I don't really want to have boiler condensation pipe hanging outside my wall.
