we have a newish Valiant non combi condensing boiler.
Currently due to warm weather, the CH is set to off. The DHW is set to continuous and the boiler fires up every 10 minutes without fail over 24 hrs even though sometimes no hot water is being used - I'm guessing the boiler is clicking off on its stat as it makes a few rumbling noises just before it switches off.
The hot water cylinder is approx 15 to 20 yrs old and is traditional copper with foam outer. The water is hot when run from tap.
My question - should the boiler be continually clicking in like this? it seems like theres a problem somewhere? maybe hot water tank coil partially blocked (water flow being disrupted) or furred up so heat from boiler not being dissipated?
any thoughts
any thoughts
