boiler help
17 Jul 2008
Hampshire
Hi dont supose anyone knows anything about a potterton prima f boiler, i have no hot water think pilot lights gone out but dont no how to reset it, :cry: [/b]
On the underside of the boiler there is a small hole with a red switch inside it. Push this switch if it feels stiff,if it's floppy then the boiler has some other problem.
Ah thanks so much found switch and it fired up straight away, ur a diamond xx , mandy
:LOL:
Poss pump is knacked, or MV faulty or OHeat stat on boiler or no water in the system.
You need to have someone look at the system.
Cheers,
Tony.
PS, I'd take a bet on the pump being the culprit. Try to run the heating and the hot water at the same time (not just hot water) and then get back to and let us know what's happing.
Hi dont supose anyone knows anything about a potterton prima f boiler, [/b]
I would hope we do as some of us repair boilers for our living!
First turn the boiler temperature knob down and see if it stays on then.
But it does sound as if your pump is failed.
See the FAQ on this site to test it.
Tony
I should hope so, some of us repair boilers all day !
It sounds as if the pump is failed.
See FAQ on this site to learn how to test.
Tony
Tony
Just had plumber out yes its the pump you were right, thankyou 4 all your help. mandy
