- Joined
- 11 Sep 2007
- Messages
- 827
- Reaction score
- 6
- Country
My boiler is a Danesmoor 15/19
For as long as I can remember the hot water in my property has taken quite a while to get hot (from when any hot water tap is turned on) but when hot is only "moderately" hot.
Yesterday I found that it was getting hotter faster, and very noticeably hotter than usual.
Nothing has been adjusted on the boiler.
However ....... this may be coincidence, but yesterday morning I removed the cartridge from the kitchen mixer tap (I wanted to check the type (a G40-03) in order to get a spare). Naturally I turned off the hot and cold pipe valves under the sink to do this. In theory that shouldn't have made any difference, but the following may be relevant: when I last had to turn the water off at the mains and empty the system (over a year ago) the only way that I could get hot water to flow in the kitchen AND bathroom was to backflush the system (put my hand firmly against the kitchen mixer tap to block the flow, turn the tap to hot and slowly open up the cold).
Before and after that exercise (over a year ago) I didn't notice any difference in hot water temperate, and this time (after checking the cartridge) I didn't need to backflush the system as I only turned off the water feeds underneath the sink.
So is the cartridge removal relevant to my newly aquired faster, much hot water, or coincidence?
